JustinWHT
- Joined
- Apr 16, 2022
- Messages
- 223
While early model Baofeng UV-5R radios were problematic (politely phrased), the quality and spectral purity has significantly improved in past ten years: dispelling early genuine Baofeng model trash talk. The fake clones were garbage. The UV-5R is discontinued and replaced with the third generation BF-F8HP.
Which brings me to the newest 5RM.
The highlights are:
* Tri-band 2 M, 1.25 M, and 70 CM
* Aviation AM monitor.
* 1.77 inch color TFF display (barely readable in sunlight)
* One-touch NOAA weather channels.
* 999 channels
* USB Type C charging cable plugs into back of battery
* Desktop charger (not compatible for UV-5R radios).
* 2500 mAh battery (not compatible for UV-5R radios).
* Like the UV-5R radios it can illegally transmit (not type certified) on GMRS, FRS and LMR channels, and (gasp) even the NOAA weather channels!
Pic of my BF-F8HP and 5RM side by side.
Redacted because I erroneously labeled radio on left as UV-5R.
The highlights are:
* 999 channels
