New Base Station Setup very quiet
Radiomatrix
Alexandria, VA
I am looking at a big failure here.
Long story short; My base station setup is very quiet.
I suspect my 40 year old A-99 has seen better days.
Replacing the antenna will be my next step: What would be a good replacement for the A-99?
dkcorlfla
Orlando
A-99 CB antenna? Are you working on a CB base station? If so what does the SWR look like?
BTW - there was a very strong solar storm that wrecked ham HF, would think CB would have been knocked out as well.
Radiomatrix
Alexandria, VA
yes, president washington base station.
1:1 channel 1, ~1.3. channel 40
QUESTION: coax comes in through the wall from outside, it runs adjacent to some 110v supply in EMT for a few feet. Will the proximity of power cables in conduit affect reception?
merlin
DN32su
With decent coax, no.
That solar storm has a heavy effect across all the VLF to VHFspectrum.
dkcorlfla
Orlando
Looks like with such a low and good SWR the antenna is good unless it is somehow acting as a dummy load ;-)
Steel EMT should fully shield or maybe a better way to say it is the RFI from the AC lines should be fully contained inside the conduit.
If the AC was causing trouble you would hear a 60 Hz buzz with a high noise floor. BTW - a quick, cheap and easy way to find AC RFI is to use a small portable AM radio and tune it between stations so it only has static. As you walk around any source of AC RFI will wake up the AM radio with the buzz.
