BCD436HP: New BCD 436 reception issue?
paddyshack
Connecticut
After programming Favorite Lists using Sentinel software, I cannot receive any CT State Police transmissions?? Need help solving this issue. (Connecticut-New London County). Thanks
paddyshack
Connecticut
I think so. I created the Favorites list, then followed the "tree" list USA- Connecticut State Police- Eastern District. Selected all and wrote it to the scanner. On the scanner, I brought up the favorites list and CT State Police was there. Not sure if that's correct. First time using scanner and sentinel software
dave3825
rebmeM evitcA
Suffolk County NY
Did you create a new fav list? If so, when you wrote, did you select Download and Monitor before or writing to the scanner?
paddyshack
Connecticut
Yes, it was the very first Favorites List item. What I did was select "Connecticut State Police- Eastern District". That produced a number of frequencies. I "selected all" and "write to scanner". On the scanner I selected "set scan selection", then "select lists to monitor", then "State Police". ??
paddyshack
Connecticut
Do you know if the CT State Police are even available or if anyone out there is actually receiving them??
dispatcher812
Connecticut
I listen to them all the time with no issue. Make sure your favorite list and and assoicated system and departmants are enabled. I have done this a few times where i set up something new and forget to enable it after.
buddrousa
NW Tenn
#1 What sites did you load?
#2 What Talskgroups did you load?
#3 What Services do you have turned on?
#4 What Favorite List Number did you Give this?
#5 Did you turn on DOWNLOAD and MONITOR for this Favorite List?
donc13
Grand Junction, CO
What talkgroup did you select and what services do you have turned on?
