new bcd436 user in Sentinel
RDCat
NooElec NESDR Mini 2+ Al: 0.5PPM TCXO RTL-SDR & AD
Vancouver
hi, i need help programming from scratch Vancouver Bc sites
1- put into sentinel
2- select services types in Sentinel?
i had system in but have erased everything and lost as can be
thanks
ofd8001
Louisville, KY
Rather than programming from scratch (a lot of things can go wrong for a new user if he isn't very careful), I'd suggest building Favorites Lists using Sentinel.
Go to the full database and expand for the desired area. Basically it's highlight the desired system, then right mouse click to Append Favorites List. Either create New Favorites List or add to an existing Favorites List.
It is daunting at first, but with time, practice and lots of paitience you should be able to do it. You'll make a mistake or two in the beginning - we all have. You can't ruin a scanner with bad programming - you can always wipe the slate clean and start all over.
There are several good YouTube videos on how to create Favorites Lists, which I recommend watching.
