New BCT-15 Cutting out every 2-3 seconds
bkthomps
I just got my BCT-15 from scannermaster, I have a weird issue that I haven't found much luck on while searching-
When scanning, I pick up all kinds of good signals, most are all 5 bars (I live in heart of downtown atlanta) but I can't count to more than 4 before the audio drops for half a second, it is VERY frustrating, if I am listening to a dispatch channel I basically miss every 8th or 9th word of what they are saying
I've tried messing with as many settings as I can, ATT on/off, delay time, etc
Anyone ever had this issue? Should I send it back? It does it on TV Station audio frequencies as well
edit: plugged up AC, using the telescoping antenna
garys
Central Texas
There are a number of threads regarding this. Check to make sure that you have priority turned off. Also check for Weather Priority, that often does it. Maybe one of the mods will make a sticky with FAQs for the 996/BCT15.
Gary
n2mdk
Ames, IA
It's one of 3 things Priority, Search or Close Call turned on. See which one it is.
bkthomps
can you elaborate on search? i was hoping to use the close call feature :( i've turned that off for now, priority was off
edit: close call did the trick! i also noticed that bear tracker (BT) mode will produce the same annoying results- is there a secret to effectively using close call without the choppyness?
warrior420
Zone 2
Close call DND mode. It only checks for close call when there are no active transmissions,.
