tandlbrewer
- Joined
- Jul 12, 2024
- Messages
- 5
I installed all new equipment. I have a duel 4ft antenna system with the antennas mounted to the fenders on my pickup. 96 f250. Ok so step by step. I mounted the stud to the mount. Checked for continuity between the mounts and the studs and there was none. Got good continuity through the studs. I mounted the antennas and got the same results all good. Mounted the mounts to the fender and retested between the mount and the battery ground, good continuity. None between the neg on the battery and the antenna stud. Checked the coax, pos to pos, good continuity in both wires. Inside pos to outside neg on both wires isolated no continuity. Attached the wires to the base of the studs rechecked continuity between pos in wire and antenna pos, good continuity. Pos on wire to stud, no continuity al good. Plugged the wire into the back of the CB, now all of a sudden I have continuity between mount and stud on the antennas. Disconnected everything and tested the coax plug on the back of the CB, I have continuity between the positive pin and the neg outside threads... Help please. Not sure what to do. My SWR is about 9 on channel 1 and 40
