New CM300d
LowderK
LEO / Paramedic
Western Oklahoma
Ok here is my issues i have 6 new CM300d AAM01JQH9JA1AN
FW R01.01.45.0001
CP 12.05.39
when i try to read or write to any of the radios is get error #101005 codeplug version not supported
I have both CPS 16 and CPS 2.0 2.18.95.0
Can anyone tell me how to fix this
KG4INW
Midlothian, VA
There's a newer version of CPS 2 than what you have now. I just had the same issue a few weeks ago with some factory fresh CP200ds and resolved it by upgrading to 2.21.
K2NEC
Oh. 2.21 is latest??
KG4INW
Midlothian, VA
Actually, I just looked and there's an even newer version now. M2020.01 just came out yesterday. They've restructured how they number each revision. 2.21 was the most recent before.
hockeyref2
Northern MI
CPS 2.24 seems much quicker when navigating around compared 2.21. Of course I have only used it once or twice - I normally use radio management.
Tech21
Did they make it any better? :ROFLMAO:
The hate for 2.0 really doesn't make sense. I program radios in 2.0 quite often and never have any issues. Sounds like some of y'all just don't know how to program radios very well.
alcahuete
Antelope Acres, California
Aside from being ridiculously slow, not being able to copy channels between zones, bluetooth programming being gone, it's indeed a fantastic piece of software! Not to mention, the rumor of not being able to use CPS if the radios are outside of the service period is apparently going to be coming true very, very soon.
KK6ZTE
California
What kind of radios are you programming? Simple 1 or 2 channel CP200ds? Or codeplugs someone else built?
I can confidently say that many of the complaints are from "y'all" who know what the hell they're doing and do it on a daily basis. There's no argument that CPS 2.0 is a major step backward in some ways from the workflow available in Build 828.
CPS 2.0 is great when you bill by the hour and have no conscience.
Firebuff880
Boynton Beach, FL
FW R01.01.45.0001
CP 12.05.39
Your problem may be that your firmware is to old. I don't do much with these, but for other subscribers you have to be much closer to the R01.12.17 release of firmware to use newer CPS builds.
I think you need to find an older version of CPS update your firmware and then use the newer code. If you search here I think someone previously had a matrix posted.
K2NEC
R01.12.17 is for Gen 1 radios like the 6550 and 4550. The CM300d do not fit this category
Tech21
Except many of the complaints about 2.0 are from your typical "radio guy" that doesn't like change and can't adapt very well.
hockeyref2
Northern MI
I upgraded some of my radios to 2.10. The older ones, I get an error saying I cant go to M2020.1 (2.20) due to the software thing, but I can still program them. I saw the same thing with my cm200d/300d's.. couldnt go to the newest firmware on the older radios. I did have one XPR3500e that I thought could upgrade but it said no, so I will have to get with my dealer. This is using radio management.
Firebuff880
Boynton Beach, FL
To go to M2020.01 you have to submit a list of radios to MSI through your dealer. Best created from Radio Manager (RM) once you have the serial numbers approved then you have some additional RM steps to take and finally you can upgrade. But reading the avilable doc why would you want to do this at this time ?
