new control channels winston salem forsyth county nc
bigdog24
does anyone know what the new control channels are now for this area and is it now p25 also my scanner stop picking up this area this past sunday please let i have a gre psr-600
ecps92
Taxachusetts
You might be best to put your radio into SEARCH (Tune) and see what you can discover as well
Then submit the new info
gspivey
North carolina
Hello, I've been listening to the WInston Salem Forsyth County system since Sunday up to today and have not noticed any difference. The control channels in the RR database should be accurate. Those are the ones I have programmed into my Uniden scanners.
bigdog24
My dad's scanner is also doing the same as my the old one has nothing on it now that's listed in the rr database
gspivey
North carolina
Try putting in all these frequencies as the control frequencies: 853.6750, 853.5625, 853.2750, and 853.2000. See if that gets you back on track.
bigdog24
my dad got his working off of 853.2750 so i programed mine the same its working now they changed it from 853.6750 to that
ecps92
Taxachusetts
Control channels can/do change regularly (rotate), Some towers will be only two CC's others might have four, make sure you have all of them in the radio, so when it changes the radio will automatically switch
Not being from the Area, are they listed in the RRDB, if not you should submit them as an update
my dad got his working off of 853.2750 so i programmed mine the same its working now they changed it from 853.6750 to that
