New CSP Dispatch Console Radio ID's?
adamfancher
It looks as though CSP's console ID's seem to have changed from the 650xx format to 653xx/654xx/655xx format...
Does anyone know if these changes are documented anywhere? The RR list for CLMRN seems to be a bit outdated...
buddrousa
NW Tenn
Then help everybody else by submitting updates for your area so the database gets updated.
CT
No. There's no area for listing of UID's
Actually, I have them as 181XXXX
BTW, This was asked in an earlier post.
adamfancher
OK Buddrousa. Thanks for your help.
Doctordialtone, there is a listing at RR, it just hasn't been updated (I am in the process of doing that now, just figured I'd check here first to try and see if I could ask a simple question without being attacked so as to add more detail to the update). I did do some digging in the hundreds of threads in the forum, it would be much appreciated if you could link me to that thread because I did not come across it in my search.
Here is the listing:
W1KNE
Owner ScanNewEngland.
Taunton, MA
The listing is in the wiki, which anyone can edit. If you want to put them into the wiki, then go right ahead. They aren't in the database.
adamfancher
I've gone ahead and done so, at this point I've filled in radio ID's that are now active for Troop B, H, C, W.
Really just placeholders for the time being, as I intend to update with greater detail (unit/badge numbers) found in the outdated records.
adamfancher
I'm in Barkhamsted today and was able to confirm activity on 1819011 and 1819012 for Troop B 1819071 and 1819073 for Troop L and have updated the console ID's on the list. When I return to East Granby I'll see what Troop H, C, and A are doing. I know some of them are still using 65xxx I just don't remember which ones off the top of my head. Once I've confirmed that they are no longer in use in certain areas I'll remove them accordingly. It seems that some troops have converted over and others haven't.
Thanks for sharing these Doc, this is really good information. Just curious, where/how were you able to find these?
CT
By monitoring. I also use a program called ID Tracker to log all of the UID numbers I am able to receive.
My records match your findings.
Doc
adamfancher
So I've noticed some 190xxx Radio ID's that fall between the categories defined at this point in time:
19015xxJudicial Marshals
19020xxUnknown
19025xxDMV Inspectors
I'm seeing signs of traffic on 1902003, 1902015, 1905018, 1902022. Hoping to fill in the blanks on this one, just throwing it out
there :)
CT
19020xxUnknown
there :)
19020xx is States Attorney.(SA)
1905xxx is DMV
Just an educated guess but I'm pretty confident.
adamfancher
Also looking at ID's 201001, 201006, and 204002. 201008 is Burlington Constable, so I'm assuming that all of 20xxxx is for Burlington
cg
Connecticut
Ct Tax Town IDs...
019 BROOKLYN
020 BURLINGTON
021 CANAAN
RIDs mostly follow the CT Statewide standard. The State Mobiles & portables are reversed, older IDs are still being changed, but other than that, the intent is to follow the state standard.
