new CTM DMR Cap system frequency
IdleMonitor
The Ottawa Valley - Eastern Ontario
143.520
I don't know much about this, but I just found it, only record that makes sense is the following:
143.5200
LAC-SAINTE-MARIE, QC (MT STE-MARIE)CTM CENTRE DE TÉLÉPHONE MOBILE LTÉE
radio shows it as a CAP system, and Colour Code 9
Can't help out with much more as it's in french.
Getting a good distance out of it though as I'm up near Golden Lake, ON and I'm hearing it from here.
Under the same call sign, this other frequency is also attached to it.
152.3150
VXL595
mmisk
Ottawa Canada
IdleMonitor; 143.520
143.520
143.5200
I receive this fine south east rural Ottawa,
Could be a single site system.
Mike
IdleMonitor
Here's what I've been able to come up with so far and have submitted it to the database.
Call Sign - VXL595
Centre de Telephone Mobile (Capacity Plus) - Mt. St. Marie
0143.520000 - Colour Code 9
0152.315000
Centre de Telephone Mobile (CTM) - (Capacity Plus) - Campbell's Bay
0162.720000 - Colour Code 9
Call Sign - VAG205
IdleMonitor
Is there anyone ouit there that is able to listen to this system? Not sure if it's a new system or part of a different system, but it certainly is active. However it's all in french. Sorry, no parlez vous francais here. :confused:
143.520 has a LCN of 1 for sure. I've submitted it to the database however there's been a slight delay in having it actually get updated.
Call Sign - VXL595
0143.520000 - LCN 1 Colour Code 9
0152.315000
DaveH
Ottawa, Ont.
Not much I can add, other than to confirm what you found. I can't hear the 152.315 channel very well,
not sure why if it's at the same site.
Systems up that way don't seem to be very busy. I check from time to time on weekdays when I have
a day off, on some systems I've yet to see any traffic. Then again, I'm usually jumping around to check a
bunch of things and don't spend much time on any one frequency.
Dave
IdleMonitor
I have 2 more frequencies that I've found recently as well too. Just no idea how to ID them for anything and they don't show up in a TAFL search either for Quebec. They're both encrypted comms. I can only assume they're from one of the Quebec systems though possibly RENIR
164.280
165.495
DaveH
Ottawa, Ont.
164.280
165.495
Those are RENIR P25 voice channels, they are all over the place. You can tell from the NAC which system they belong to, although NAC varies with site.
DB hasn't been updated much over the last several years. Some new sites have popped up.
Dave
IdleMonitor
Dave
Do I have to enter them in as a conventional mode first to get the NAC etc.? Because nothing shows up other then they're encrypted while in search mode.
I've stuck them in as an extra site for the RENIR system for now but I'm not getting anything for ID or site number etc.
Sent from my SM-G390W using Tapatalk
DaveH
Ottawa, Ont.
Not sure how your scanner works, but on the PSR600 I enter as a conventional channel, or easily as a "tune" frequency, a sort of VFO. The system ID is 14F so the NAC on a VC should appear as 14x depending on the site; I forget the finer details. It helps identify these encrypted channels in case you run across them later while looking for something else.
Dave
IdleMonitor
Not sure which system this is part of, but while out and about today I was able to pick up 153.500 CC 9
Anyone in the area have any more info?
Btw, it's a amazing the distance of stations one can hear while up near Foymount, ON even while mobile. I wasn't even in the village but on a road not far from there and was pulling in stations from all over. I'm gonna take another trip up that way someday and do some serious frequency searching.
TAFL Search Results
DaveH
Ottawa, Ont.
I've heard nothing on the other frequency 162.300.
As 153.500 is Cap+ and the rest-channel activity comes and goes, there must be one or more other frequencies involved.
Dave
mmisk
Ottawa Canada
143.52 ► Site 4
I had another look at 143.52.
If this is correct is says Site 4, wherever that is.
Cap+ Site=4 RestCh=1
+DMR slot2 BS DATA DCC=9 CSBK Cap+ RestCh=1
+DMR slot1 BS DATA DCC=9 CSBK Cap+ RestCh=1
+DMR slot2 BS DATA DCC=9 CSBK LCP IRB Sync; Site=4 Res
tCh=1 Neighbors = 1 2 3 5
+DMR slot1 BS DATA DCC=9 CSBK ERR1 LCP IRB Sync; Site
=4 RestCh=1 Neighbors = 1 2 3 5
mmisk
Ottawa Canada
Dave
These two frequencies seem to belong to site 2:
153.500 1 2 Site 2
143.910 3 4 Site 2
Ttracking of voice comms and CC is correct.
EDIT: TAFL says this is Camp Fortune
IdleMonitor
Site 4
https://www.radioreference.com/apps/db/?sid=9685
IdleMonitor
Talkgroups captured across these sites
Site 1 - Campbells Bay - https://www.radioreference.com/apps/db/?sid=9684
162.720 - LCN 1 - CC9
Talkgroup 6
Talkgroup 9
Talkgroup 12
Talkgroup 19
Site 2 - Camp Fortune (Not in the database yet needs to be submitted)
153.500 - CC9
143.910
Talkgroup 6
Site 4 - Mont Ste. Marie - https://www.radioreference.com/apps/db/?sid=9685
143.520 - LCN 1 - CC9
Talkgroup 5
Talkgroup 6
Talkgroup 8
Talkgroup 9
Talkgroup 11
Talkgroup 12
Talkgroup 13
Talkgroup 19
Should the database be updated as one system seeing as they have seperate site #s? Or are they still considered seperate systems?
