New Dix Range System
jeff
St. Augustine, FL
I'll submit to the DB but here's a heads up: Fort Dix has installed a new 380 mhz P-25 system for their ranges. The 400 mhz analog system is removed. The freqs are: 388.0875 (CC), 389.0625, 389.175, 389.3375, 389.575, 389.95. TG's are in the 40xx and 41xx series. This will eventually be tied into the Lakehurst 380 site and the McGuire 380 site (not yet constructed) to create a 3 site Smart Zone system for the Joint Base.
Skypilot007
Medford, NJ
Cool...thanks for the info. I can't copy the Lakehurst site from my location, perhaps I'll be able to tinker with this one.
jcardani
Orlando, FL
I am getting about S-5 signal with antenna pointed NW. Should improve a few points if I point NE.
wnjl
Tabernacle, NJ
Also getting a signal from the CC here in Florence. Just curious, what kind of traffic is usually on the range system? (Didn't have the 400 mhz system programmed in)
ecps92
Taxachusetts
See if you can get the NAC. It's helpful to have, when searching and you find the Voice Channels, but not the CC, when attempting to ID Thanks
jeff
St. Augustine, FL
You'll hear range control talking to the ranges for opening and closing, range maintenance activities, some training activities such as convoys. They are currently using the McGuire trunk system on TGs 1840, 1872, & 1904. Users should be on there within a week, awaiting some consolette installations.
jcardani
Orlando, FL
Hi Jeff,
Which 400 MHz Range trunked frequencies will be replaced and removed?
thanks
jeff
St. Augustine, FL
The range site which had 406.3625, 407.475, 410.5625, & 410.7625 has been removed. Also in your military guide you had some 78th Div conventional 400 repeaters listed, they have been removed. The site on McGuire is still there, it probably won't be replaced by a 380 system for 2 years.
W2GLD
Michigan
Picking up another new CC on 386.8125
Sysid: 14C
NAC: 140
Site: 015
It's about an S4 here at the moment.
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
Sysid: 14C
NAC: 140
Site: 015
Sysid: 14C is commonplace with the U.S. Dept. of Defense's new P25 trunking systems. Looks like they have been adding a lot of new sites on the East Coast lately. However, without looking it up in the database, this maybe the first one in New Jersey.
73s
Ron
ocP25bandit
386.3125 cc.......... SID: 014Ch-0310 5 bars
386.0750 cc......... SID: 014Ch-0311 4 bars
All in Ocean County
elias1988
West Creek,NJ
Heres tower data from Pro96com:
FileVersion:6
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 14C
System Name :
WACN : BEE00
Tower Number (Decimal): 310
Tower Number (Hex) : T030A
Tower Description : (null)
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Fri Mar 4 10:15:11 2011
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625,1
02,380.00000,0.00625,10.00000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Frequency(/Slot),Hit Count
"02-0986","a",386.16250,396.16250,0
"02-1010","c",386.31250,396.31250,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
311,"T030B",14c,"02-0972",386.07500,""
KC2GVX
Toms River, NJ
Forgive this stupid question, but it has been a while since I had to program my PRO 2096. I noticed the steps on the 2096 do not correspond to these new systems, and it does NOT pick up the CC on the next closest freq. Can Win 96 do this?
robbinsj2
Bridgewater, NJ
A more fundamental issue is that the Pro-96/2096 is unable to trunk 380MHz P25 systems. It rejects any base frequency in the UHF band below 406MHz. Win96 appears to accept it but when you upload to the scanner it gets lost.
To answer your actual question, in case you're looking to scan it conventionally, Win96 can unlock that frequency range however it does not change or override the radio's channel steps. 386.1625 typed into Win96 automatically gets rounded to 386.1650. I would have guessed that 2.5kHz off is close enough but you note that wasn't your experience. I'm not within range of the system to try it myself.
Jim
