DRL-XM43
Make sure your FMPA (or FMP24, whichever you use) is set to 9.5 khz filtering. And if you are monitoring a simulcast site you must use FMPA or FMP24 as the control receiver.
Are you using a 0.x ppm dongle or an Airspy? Or are you using one of the ancient dongles with that tend to be off frequency? If so, you'll have to give FMPA|24 time to hone in on the signal if it happens to be off frequency.
Mike
I have the -b9.5 switch in both my FMP24 batch files. CC accepts it but VC changes it to 12.5 any way to force it to be 9.5 or is DSD+ recommending 12.5 in spite of the -b switch?
