New Firmware Just Released 1.34
WB6WQF
Sacramento, California
My dealer reports that Unication pulled 1.34 because there were bugs and that 1.35 was just a fix to correct some of the biggest bugs. I was also told that 2.01 will be the next release and on the website when it is ready. My dealer recommends that customers not upgrade from 1.33 at this point.
ArkTex
KA5AAA
Little Rock, AR
I just received a new G5 today and it reports having FW 2.01 already installed. This was right out of the box straight from Ray's Pager Sales. I'm surprised it hasn't hit the website yet.
belvdr
No longer interested in living
It is only for new hardware at this point.
FW 2.01 was created to deal with new chips being used in the pagers because the older chips were not available. The 1.3x FW was not compatible with the newer chips. Future versions of the FW should be compatible with both versions of the chips, but until Unication finishes writing and beta testing it the two versions of the pagers (one with a N in the serial number, the older version without it) there will be two different versions.
The two different FW versions may be why it isn't available on the website, they don't want people using the wrong one thinking it is an upgrade.
belvdr
Wasn’t that the purpose of AutoUp, to provide the correct firmware for a given serial number?
N4VKF
SPOTSYLVANIA,VA
I guess I need a G5. Might have to wait until 2025 to keep my new years resolution.
WB6WQF
I just loaded FW 2.02 onto my G5 and will report back If I find any bugs. I am also running PPS 4.0.39.
Current Software > PPS: 4.0 (V0.4.0.39) Firmware: V2.02 Released: 2024-03-11
WB6WQF
There's possibly a bug in the new FW. There now are times when the G5 remains un-squelched after the end of a conventional analog transmission. To squelch the unit again it's necessary to either switch to a different channel and back again or to wait for the next transmission. It doesn't appear to be a noise floor issue.
Ok ill feed the troll..
Gee Where did you get that software and firmware, no one else has it and its not on any sites
I for one would love both!
Please remember the V2.xx FW is for the G5N version, the ones with the newer chip, it is not an update for V1.xx FW.
WB6WQF
Unication has pulled their updates so I’m pulling my link.
Just fyi to anyone who wants to test the update, I tested moving between versions and you can’t downgrade to below 1.35.
No issues detected other then the squelch issue reported above (which happens rarely).
