New Firmware/PPS Release for G2-G5 Voice Pagers (V2.04 & V0.4.0.46)
Just completed the update took about 15-20 minutes and had no issues. Follow the instructions and you should be fine, make sure pager is charged before you start.
K9KLC
Southwest, IL
I’m interested to see the results if anyone tries this on the older G5’s. Version 2.02 was very sluggish on mine so I ended up reverting back to 1.35.
I'm still at 2.02 on one of mine and 1.35 on the other. At times it seems the older FW works a little better but then at other times not. Maybe just me. I normally don't do anything fancy with mine but on occasion some full spectrum scan on a trip. I too would interested in other results. My pagers are from likely 2019 from what I can tell.
My G4 seems to make more popping sounds while using it on the charger amplifier.
blackbelter
So I understand this update only applies to Ver 2x and PPS 4xx …
Since most of these latest updates addresses few under the hood stuff, I have decided to stay with the 1.35 which displays no issues .
Phillipsc84
Fort Mill, SC
I cannot stress enough how these need to have a manual band plan setting. With some systems not broadcasting the IDEN channel plan and on sometimes busy systems the pager cannot "find" the system without it.
pboissy
ENFIELD
Thank you, that's interesting. I have not done the upgrades yet, I've never been one unless there was a problem to jump on the latest release of firmware, but that's just me.
If I could ask please, what firmware did you have in the pager?
I had the previous version.
K9KLC
Southwest, IL
Thanks, truthfully I'm not having any issues with my 2 G5's on the firmware they're currently running. Both are used a lot in the amplified charging bases, so I think if anything I'll try one and see how it goes here or, leave well enough alone for now and see what others report.
Ya I've still got one on 1.35 and it's staying there unless something pretty dramatic happen with the firmware to entice me to change. I play with the one and it currently has 2.02 on it I may get the update on the one that has 2.02 on it and see if I experience this popping a couple of the guys are talking about there on my charger.
