new firmware
I900D658
sarnia
gents i have downloaded the new firmware 1.15.00 thru sentinel. the download appeared to go thru alright, but my 536 is still showing 1.14.00. is the firmware not working
thanks
jonwienke
More Info Coming Soon!
VA
Read, then post. There is an entire thread about this already.
CorwinScansNM
NM
correct. the 1.15 is not working so stand by.
OK, so should I not download & apply the latest Uniden BCD*36HP firmware upgrade 1.15.00 for now & give Uniden some extra time to fix the issue with the firmware upgrade? I currently have the last latest firmware version downloaded & applied to my Uniden BCD536HP being 1.14.00
I will keep checking on this thread to see when it is considered safe & effective for me to download & apply the latest Uniden firmware upgrade to my scanner through Sentinel being the 1.15.00
Voyager
thanks
You actually downloaded 1.15.01 which is identical in every way to 1.14.00. The 1.15.00 firmware was pulled due to issues.
It's called 1.15.01 so Sentinel would see it as "newer" than 1.15.00.
May as well type this since someone will point it out as a bug:
The current Sentinel download will DL the firmware on every attempt due to the way the reversion had to happen. That is a side effect of the reversion.
KE4ZNR
Radio Geek
Closing this thread with the release of firmware 16.
Sent from my Pixel XL using Tapatalk
