new frequencies for the LAFD Co on the ez scan program
LB_Scan
Hi
I like to know when the new frequencies for the LAFD Co on ez scan program. When i go to county fire ems citywide it has the old frequencies listed. thanks
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Have you updated the library?
Update the Library (Database) in the Software
The database is updated every week. In the EZ Scan/iScan software, click the Updates menu then Check for Library Update. Follow the prompts to finish the update. You will also have the options to copy the database to the scanner (follow the prompts) and/or update objects in the software.
LB_Scan
The old Channels LAFD Co on my ez scan program
New Channels LAFD Co on
Code:
https://www.radioreference.com/db/browse/ctid/201#cid-110
IC-R20
LoBand Nation
There's an option when you update the database to have it update your stored channels as well.
Seems like my TRX-1 is going to be a expensive paper weight soon?
While Whistler is still having issues and everyone is giving up on them, you can always learn how to update the scanner manually or download the most recent version of the database library files at the link below, or you can sell me your paperweight for $25 :)
eryoung2k
Bridgewater Ma
I did not know there web site was back up, the last time I checked it was a unusable disaster. Thanks for letting me know it was back up and running. The last few times I updated it I did it through the website when it was working.
