New Frequency INFO
J
justy
Guest
I Have Some New frequency Info For Yall The Johnston County Sherriff Is Encrypted But Here is Some of the Frequencies The 911 Center uses.
867.300
868.550
866.300
867.700
Smithfield 855.7125
And Im Asking For KE4ZNR TOO PLEASE Leave This Forum open.
Thanks For All The help Everybody Has Given Me.
And Heres Is A Frequency That I Listened Too While I Was In Craven County 156.210 Thats Not the main Sherriff Dispatch Channel Theres Not A Lot Of Activity.
But You Can hear A Little Activity On there Now And Then and 155.685 is the sherriff dispatch Frequency.
and i dont see the Clayton EMS Chaging Too Viper Anytime Soon.
If Anybody Has Any Questions Im Hear Too Answer.
J
justy
Guest
New frequency Info
Ok I Will Look I Just posted this for anybody that dont already know.
blueline_308
Eastern, NC
To clarify things who might read this...156.210 IS the main (primary) dispatch freq for Craven SO and 155.685 IS the secondary or, TAC as they call it, for the Craven SO (it is the OLD New Bern PD channel which they used prior to the switch to 800. I listen to both freqs everyday. They are both repeater output freqs.
Jim
J
justy
Guest
And I Found this new Feature On My Pro 97 Hand held Scanner Its Pretty Cool Its called A CT Scan Those of you That Has A Pro 97 Yall should use it.
go too www.google.com And Type In Where It says search.
and i was going by what it said on the craven county database.
zmanpro96
Johnston County, NC
Dude, Justy all the information you provided is already in the database..The JC freqs you provided are probably from the Southern JC Site....Man so some research before you post next time...
