It is normal to have loud hissing audio always while audio is playing? It is only when the audio is playing. It mutes after the talking finishes. This "air" noise when the internal amp turns on is the same at high and low volumes (very annoying).
The air "hissing" sound remains the same so very prevalent at low volume, making it all but impossible to listen at low volume. In fact to understand the traffic you need to listen at 50+or greater (often times 65 or greater, which is not ideal when you just want to quietly listen and not disturb others). This is listening to P25 Type 1 OHIO MARCS system.
I scoured the forums and found one other forum entry with this issue going back to 2017 however none since. Since my unit is new and I just received it last week I wondered if I received is a lemon? Everyone seems to rave how much better the audio is on the Unication G4/G5 compared to the Uniden SDS series however that is not the case with mine. I have had a SDS-200 and have a Whistler WS1080 and a Pro-197 that I can listen to the same system at quiet volume and hear/understand the conversation and both without a loud background hissing noise.
I tried to re-install the latest 1.31 firmware to no avail. I even tried the three-button reset.
