New G4 Audio Died
doc62
Received new G4 on 25 August. It came with Firmware Version 1.3. Programmed it. Worked great until today. Today the audio stopped. The display shows the unit receiving, but no audio. Not my first Unication. I also have a G5 (running 1.2). Waiting to hear back from Unication now.
bob550
Albany County, NY
You didn't accidentally activate "Push to Listen" in tab 6 "Zone and Channel Setting" by any chance? Other than that, you should contact your dealer.
doc62
No I didn't. It was working fine since Tuesday. I was in the station for a call this afternoon and noticed that the in-station G4 was talking, but the my G4 wasn't. It had been working when responding to the station.
K6LEH
Oakland, CA
Have you tried removing the battery?
doc62
Multiple times hoping it was that simple. Even pulled it for over 10 minutes, but no joy.
w2lie
New York DB Admin
Long Island, NY
If you contacted Unication, they will forward you to your dealer. Dealers are responsible for opening up tickets for repairs.
doc62
I've already been working with Ray on this. He had me re-flash it, but that didn't help. Filled out the form. Just waiting to hear back from Unication.
N6ML
You've probably cover these already, but a couple of other thoughts ....
Is there a speaker icon, without an 'x', on the display, when it's receiving?
Can you play back recorded messages?
Do you have a BlueTooth device that you can try to use instead of the internal speaker? (just to prove that it's really an audio output issue)
Uni1
Unication Representative
DFW Texas
Off duty? Is the poerso icon yellow at the top of the screen?
picscan
CA
If you press the yellow dot button and scroll down to the bottom what does it say?
doc62
The G4 was new, but I've had a G5 for sometime. The main difference between the two is the VHF parts and of course the G5 is still at 1.2. The icon did show yellow (On Duty). I don't have the unit anymore. Ray had me send it back to him. I tell you he is second to none when it comes to support. I'm just wondering if this was a case of infantile failure. Not uncommon with complicated electronics. The only issues I ever had with the G5 was that sometimes when you turn it on, it doesn't really turn on and you have to turn it back off and on again. Have been afraid to update it to 1.3 until they get the 2-tone alerting figured out for the VHF. Don't want to miss any calls for my station.
CFP387
Rowan County, NC
I had this same problem with a G5 a few days ago after flashing it with the latest firmware v1.4.
I pulled the battery to reset it, then wiped the memory from the pager. I re flashed it and it's working fine again.
mpreece
Wyoming
I've reverted my VHF G5 to v1.2 twice due to various issues. I am now on my third install attempt for v1.3. Disappearing audio is an issue, although making changes in my expectations and resulting programming changes seems to have the unit performing to 90% of the v1.2 2-tone functionality.
Back to the topic, I have had several occasions where I will look down and the unit appears to be receiving but no audio output. No visual indication of the speaker icon being x'd out. This may account for some of the "missed page" issues. I momentarily change the knob position and then return and audio is back.
I have not identified a sequence of events that causes this "silencing" of the audio but I have a theory that it may be related to the verified problem of timers ceasing to function when the screen display times out. I am hoping that when a fix for the timer issue is identified that it may also solve some of the other issues.
doc62
So I sent the unit back to Ray. Initially it worked (figures), but it did finally act up and he was able to send a diagnostic log to Unication. A replacement is now on the way. Like I said Ray is great to work with.
doc62
Well the replacement G4 arrived Wednesday from Unication. Got it programmed and so far so good. I tell you Ray provided excellent support and follow-up with this issue. He is definitely a good person to work with. Also kudo's to Unication for standing behind their product.
