New G5 Question
minasha
NYC
I have a new G5 model # is: G5B67BF-SXUDEN1401UNI-0002-180625 I was told this pager is ready for DMR right out of the box.
Is this true or does it still need to go to Unication for upgrade?
N6ML
In radio reference NYC, other Fire / EMS 4th line down, firstresponder ambulance shows CC=10 TG=* SL=*
Hmm If I had to guess, it might mean that they use both timeslots, and various talkgroups.
minasha
NYC
I am trying to test out any working DMR channel to verify I can receive them My UHF split doesn't cover Ham I have (450-520mhz)
Being from NYC you would think that would be easy but I can't find anything working yet.
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
If its a trunked system, You wont be able to follow it thru the channels.. If you have a Ham radio, try putting the frequency in and use the Monitor or Permiscous(?) mode to find the slot and TG
minasha
NYC
Can't get Ham channels it's 450-520 band split D
AdamHLG
With that band split are you also going to be monitoring FDNY borough of Manhattan K? If so I would be curious how the Unication does in and around the City on those 482 - 485 mhz frequencies.
minasha
NYC
I am still setting up code plugs but if I include the FDNY I will let you know
blackbelter
How would I program the following DMR system in my DMR capable G5? I know the CC which is 8, however I am not sure of the Tgs.
LocFrequencyEmissionClassUnitsPwrLatLonCityCountyState
1463.87500000FB2140.000-
2461.47500000MO244.000
2463.60000000MO244.000-
2463.87500000MO244.000-
2463.90000000MO244.000-
2468.87500000MO244.000
Hit_Factor
Saint Joseph, MI
Just put in the DMR wildcard I mentioned for TGs. It's in the other thread on the same subject. DMR Question for G5
Program everything twice, once for each time slot. Then delete the incorrect timeslot.
wa8pyr
Technischer Guru
Lead Database Admin
Ohio
No one has verified the TG or Slot assignment
Both answers are correct; the asterisk is a wildcard which will allow any color code, time slot or talkgroup to be monitored. If you want to listen to everything without programming multiple time slots, talkgroups and color codes, you can simply use the wildcard to pass everything.
minasha
NYC
[/QUO
The TG and CC and slots won't allow an asterisk only hex or decimal
wa8pyr
Technischer Guru
Lead Database Admin
Ohio
You'll have to verify what's what, then. Scanners will permit a wildcard, evidently the G5 does not.
