Hi I have scanner sds200 tring to program I get my local area but I dont get full broadcast when I bought there was extra software I could have bought I should have cause now I want it and can't find it im n bay area if someone can help id be very thankful
If you 'just received' your SDS200, it's extremely likely that the database on the scanner is a year or more out of date. As Eng74 has suggested, you will need to install Sentinel on your PC in order to maintain the database. If you have not yet done so, you can find a link to download the software on this page:
info.uniden.com
(The same version of Sentinel is used for both the x36HP series of scanners as well as the SDS scanners like your SDS200.)
Once you have installed the software, then update the database for Sentinel. Once you have done that, use Sentinel to write the update to your scanner.
See this Wiki page for links to various topics on using your SDS200.
wiki.radioreference.com
Also, when the scanner is first shipped, and also when Sentinel is first installed, only the Dispatch service types for public safety are enabled. Those would be Law Dispatch, Fore Dispatch, EMS Dispatch, and Multi-Dispatch. You also need to enable the
Talk and
Tac service types for each of those, such as Law Talk, Fire Tac, EMS Talk, etc.
