Request for assistance
Guys,
I need a few of you who know & use P25 monitoring software often to run a few days of logging on the main simulcasts that you live in.
We are in the process of cleaning up the NJICS DB entry & one of the things that needs to be re-visited is the NJSP talkgroups that can sometimes appear at the same time on both systems.
The functionality seems to be drastically reduced compared to the months right after the core part of the system came on line. As an example, through both of the last 2 major storms & normal daily monitoring here on the Hunterdon Simulcast, the only thing that gets ported over on a regular basis is the Troop-B 4-COMM and 5-COMM talkgroups (and not all the time, either).
Just because it's possible for the system to cross-connect the 800MHz talkgroups to the 700MHz system, does not mean they should all be listed on the 700MHz side. I want to get as close to 'accurate' of an update about what's really being simulcast, so I need some help from those in Central and South Jersey.
Thanks in advance!
Guys,
Thanks in advance!
