New member, not hearing much
kenworth99
WALTERBORO, SOUTH CAROLINA
Bought this new BCD536HP for my wife for cchristmas. Put in zip code and it shows its scanning but only hearing neighboring county. Live in South Carolina, Colleton County. Any help understanding this scanner would be really appreciated. Thanks. James
troymail
Silent Key
Make sure you've updated the library on the SD card....
Press the SERVices button and enable more/all of the services (for now).
FWIW - many times, zip code programming will try to load so much stuff, it will take forever to scan through everything and alot of what it is trying to scan won't result in activity.
You can also go into the menu and disable nationwide and other frequencies (I believe).
Ultimately, you'll eventually want to program the radio more specifically to receive things in your area that you want to hear....
jonwienke
More Info Coming Soon!
VA
The first thing to check is the actual location being used. The scanner uses GPS coordinates to decide what to scan. When you enter a ZIP code, the scanner looks it up and uses the coordinates of the center of the ZIP code area, which may be many miles from your actual location. Is the scanner actally trying to scan your local system?
Your best bet is to look up your actual location on Google Maps, and then enter your actual coordinates in Sentinel. Click the Edit Profile button, then go to the Location Settings tab. The Range setting controls how far outside a city or county you can be and still scan that jurisdiction. Typically you want to set it at 10 miles or less, or the scanner will try to scan too much stuff.
The next thing to look at is Service Types. Uniden has most of them turned off by default. Turn on all of the EMS, Fire, Law, Interop, and Multi Service types.
You also want to consider your antenna. An indoor antenna is not going to get very good reception, and is only suitable for strong local signals. If you want consistently good reception, you need an outdoor antenna designed to receive the bands used by your local agencies. The telescoping antenna that comes with the 536 is not really a multiband antenna; you have to extend or retract it to tune it to a particular band. You may need to experiment to see what length gives you best reception.
kenworth99
Well I've turned off things that I wouldn't need in order to just listen to the city of Walterboro, and Colleton county but we still haven't heard anything come across the scanner. But we do hear sirens going. Any other ideas would be much appreciated.
troymail
Silent Key
Save the attached (below) ....
Then, unzip it --
Then, in the Uniden Sentinel software, import the enclosed file which is alled Colleton County Area.hpe using File -> Import From hpe file...
Then, using Sentinel, write it to your radio/SD card....
Make sure all SERVices are enabled.
  • For kenworth99.zip
