New menu
TXEMT
San Antonio
I just got my radio back from the shop and was looking through the list and on the revisions menu i noticed there was no Radio ID listed anymore? seemed werid, also there are a couple menus that were not there before like FCC Menu which has a, couple of options that show letters and number and some kinda of cooridanate that moves around when the radio does, also key load and tx power showed up..any help on what these are
WCRadioGuy
Salisbury, MD
These are programmable menus. You can add and delete whatever menus you wish to see in ProGrammer. It is under Options, Programmable Menus.
ElroyJetson
"and some kinda of cooridanate that moves around when the radio does"....???
GPS?
Tell me more about that, please.
And tell me what model radio you have and what your radio code and DSP versions are,
plus your list of features.
Elroy
TXEMT
San Antonio
it does not look like gps, it is under the fcc menu heading, the radio is an older Jaguar 700P sorry forgot to mention that, when i hit the fcc menu heading the first thing that pops up is exatly this on the screen... C 2 -102 and that number changes all the time from 102 to 90 and sometimes lower. When i go throug that menu the next thing is "RUN HDT" no Idea what that means, next thing is S11 C 2 Then RTRY 0, thats all under the FCC Menu heading.
DSP RAM I4R05K01...think that is what you asked for
Features are 4,5,6,7,8,12,16,21,22,23,29. It is a provoice system using esk.
Also under the Features heading it has Feature Data 1,2,3 each with different serial number
Also no Radio ID listed under Revisions anymore, use to have one listed
Would call the local radio shop but they don't have time for curious tech questions..they just ask is the radio working
EDACSTECH
Ocean City,MD
C2 = Channel or Repeater Two & -102 = the signal level that the radio is receiving @ -102 Dbm. The lower the number the stronger the signal.
JungleJim
What version of flash code do you have in the radio?
Key Load would be to load the encryption keys if you had any.
TX power switches your transmit between high and low power mode to conserve battery.
otter9309
On the move
Your flash code should be S105F00. This is a Beta flash developed for the SA/BC system.
S=Site Number
C=Channel in use on the site. If you watch it will change as a GID becomes active. When idle, it shows the control ch.
