Yesterday (3/24) the "Scan" TGs started have comms on them. This could be good since my reg otherwise reception of Lake Co isn't good.
Mutual Aid without the need to change zones or grab a different radio, simply select that talkgroup and you are patched to that dispatch full time.... Im sure the need is for LEA Pursuits South toward Newton or West toward NewtonIf somebody "in the know" can explain why that's needed, I'd like to be educated. If it was for fire channels/mutual aid, I understand that.
When hearing about SAFE-T TGs being patched onto county-owned radio systems on a full-time basis, I've always been under the impression that those are receive-only channels.Mutual Aid without the need to change zones or grab a different radio, simply select that talkgroup and you are patched to that dispatch full time.... Im sure the need is for LEA Pursuits South toward Newton or West toward Newton
bee listening all day, been seeing scan-lake, scan jasper and scan ISPSeems the ISP isn't working right now, there's traffic on region a ma 1 and nothing shows on pro96com now after it worked early today. Jasper and lake still working. Jasper in pursuit that's why I noticed ISP not working now.
I noticed ISP Scan pop back up around 16:35 on pro96com.... I didn't have time to post about it. It is actually pretty amazing to get these on the county system. Gives others who might not be able, the ability to hear those 2 dispatches. I already got them on my other scanners, so I just locked them out. I like to keep my phone county with its own scanner to hear everything I can.bee listening all day, been seeing scan-lake, scan jasper and scan ISP
Those were radio techs on EMA TG I'm pretty sure, one of them was from the testing Monday and Tuesday, the other 2 I'm not sure. Im try post the recordings later or when I can so others can listen if they choose.They just had, I think, EMA running around the county doing radio check with car radio's, and lapel mic's, with windows up, down, cracked, etc...
www.scadacore.com
Is this as hobby or as work you are doing this? If work can u bring up a couple things to them?I am heading to Newton on Thursday to do signal strength tests and antenna system testing.
If you guys want to see what kind of coverage each site should have try plotting signal strength with these tools.
Radio Mobile WEB Site
www.ve2dbe.com
RF Line of Sight - SCADACore
RF Line-of-Sight provides radio path information for mapping long distance SCADA radio communications by using antenna height and topography.www.scadacore.com
RF Toolkit - Nautel Support
support.nautel.com
770.08125 and 770.09375 rotate daily at 3am now, and pro96com shows 771.08125 and 771.09375 as backups. As of right now the CC is 770.08125.What freqs do you see control channels on? Their application is for 770.08125 and 771.08125.
The obvious answer is: until all departments get new radios.Question for Speedway Nav or MMcKenna. Since this is your profession, how long does this Newton County system keep transmitting across 3 different systems? I know it's still in testing phase but, what is the end goal?
