New offering - RadioFeed 1.0
ProScan
Software Provider
Ontario, Calif.
For someone who is new to the scene, I am still not sure how exactly RadioFeed works. Can one take any FCC-approved frequency and then listen in? Or do I have a completely wrong idea about it? Any help in helping me understand it is greatly appreciated. Thanks!
Are you asking about becoming a stream provider or listening to a stream with a media player?
No such thing as "FCC-approved frequency". Anything can be streamed on RR that meets the RR Terms of Service criteria.
Feed Provider Terms of Service - The RadioReference Wiki
I would start with the Wiki's especially the "Providing a Feed" section.
Live Audio - The RadioReference Wiki
JokeInsurance
NOVA
I was asking if you provide the latter, as in listening to a stream with a media player.
Bote
know-it-all
Ft. Lauderdale, FL, U.S.A.
Wow.
RadioFeed is a software application that allows the user to send digitized audio to a server for mass distribution over the Internet.
RadioReference.com is a huge web site that includes many scanner streams that you can listen to with any number of players, but not RadioFeed since it is not a player.
This forum thread is about RadioFeed operation and bug reports.
JokeInsurance
NOVA
Wow.
Relax dude. No need to be mean about it. Remember the rules of the forums. Regardless though; thanks for the info.
W2PMX
Fayetteville NC
Bob,
Do we use RadioFeed instead of RadioReference's ScannerCast, or in addition to it? I haven't downloaded ScannerCast, but it looks as if you duplicated its functions, so we use your program instead. Or am I seeing things wrong? (Since I have a spare scanner, and a spare computer that's on 24/7, I might as well provide at least one feed.)
Bote
know-it-all
Bob,
Use either one. I prefer RadioFeed, having used it for several months now.
Just be sure to set your audio levels properly so that you get a good sound out of it. Not too loud, not too soft.
Cheers!
ProScan
Software Provider
Ontario, Calif.
Bob,
Say what? Heck, I added functions and still have more up my sleeve. Anyone that has used my ProScan and RadioFeed knows that I put in every feature possible under the sun.
Next will be a Spectrum Analyzer and Oscilloscope. Down the road will be DSP filtering such as 60 and 300 cycle notch filters.
gfdfortynine
Eastern, Ontario
Thanks for developing software
I just installed it and now using it to supply my feed. Easy Peasy :)
I like the monitor feature, I can hear my scanner again.
KC9JUM
Indianapolis, IN
Curious product.
I have a few questions......
I am a Server Admin in my day job and it causes me to set up my stream server in what is probably different way to most in here.
The first is that I run a true server OS. Right now Windows 2003 Enterprise Server but I do have access to 2008. How well does this program play with the server side OSes?
The second is that I have a rule that everything must be able to run as a Windows service to perform it's function. Less resources, more stable. I have a third party program (Firedaemon) to do this if a program (Like the DNAS server instance the Winamp running the source) does not. Does the program start up and auto start streaming on launch?
You mention a web server. Can you change the default port? I am allready running a webserver on port 80, and the stream admin page would need to be on a different port.
This program is rather timely. Shoutcast V2 looks like a pain in the rear...... a bunch of garbage for the musical folks we never will use. And the dopes took down the V1 software off thier website.
I never liked running the consumer oriented winamp anyway on a server anyway.
The whole setup runs on a DELL GX620 (mostly because thats the last Optiplex with the LINE IN port).
I do have two griffin IMICs as well as the onboard LINE IN port in use, the two IMICs are used for ATCSMON http://www.atcsmon.com/ Is there a way to make sure the program allways defaults to the onboard sound. Admittedly even the source in Winamp will misbehave and try and my listeners don't like to listen to streaming digital data LOL!
BTW, here is my stream
Indiana Railroad
KC9JUM
ProScan
Software Provider
Ontario, Calif.
Curious product.
I haven't had any reports of problems on the various flavors of Windows ? RadioFeed is time tested but I would test it on the OS to be sure.
RadioFeed can start up automatically and if the option is on "Start Up - Source Client and Web Server Use Last State When Program Closed"
then it will start with the Source Client and/or Web Server turned on.
Any port not in use can be selected.
I do have two griffin IMICs as well as the onboard LINE IN port in use, the two IMICs are used for ATCSMON ATCS Monitor for Windows Is there a way to make sure the program allways defaults to the onboard sound. Admittedly even the source in Winamp will misbehave and try and my listeners don't like to listen to streaming digital data LOL!
The Input Sound Device can be selected and will retain the setting when the program closes.
Indiana Railroad
KC9JUM
W2PMX
Fayetteville NC
Oh, I didn't mean that you only duplicated all the functions, I meant that you duplicated all of them. (Then I realized that my question was the result of not actually reading everything.)
Feature creep. The sign of someone who enjoys programming. About the only programs I've written that I'm not still "improving" ran on Z-80s and 6502s (because there's no point any more).
How about a 300Hz (it's 2011, although I still find myself wanting to type 'cps') high pass and a variable low pass that cuts out at about 3kHz -5kHz? (At about 12-18db/octave.) Keep the noises out of the stream.
My only other question is - where were you about 9 years ago, when I had to build a streaming system out of the junk that was all we could get then?
ProScan
Software Provider
Ontario, Calif.
RadioFeed 2.0 Is Out
RadioFeed 2.0
  • Added - Audio scopes. Double click to change mode.
  • Added - Web Server - Password protect audio stream option.
  • Added - Broadcast Lock Out Indicator.
  • Fixed - Metadata - Digital channels text tags on the PRO-106, PRO-197, PSR-500, and PSR-600.
  • Many many small improvements.
At this time, there are no known bugs or issues.
RadioFeed is available at ProScan on the right side.
Text Tags supported on the the BCD996XT, BCD396XT, BCT15X, BC346XT, BCD996T, BCD396T, BCT15, BR330T, BC796D, BC785D, BC780XLT, BC296D, BC250D, PRO-106, PRO-197, PSR-500, and the PSR-600 scanners.
RadioFeed is the most powerful and feature rich streamer software in this world.
Edmonton, AB
I think I may have found a small bug with version 2.0.
When streaming to a shoutcast server, the listener count always shows 0 even though according to my shoutcast control panel there are currently 30 listeners connected to the server. I was thinking that perhaps it just takes a little while for this info to refresh, but I've had RadioFeed 2.0 connected and streaming for 7 minutes with no change.
NYRHKY94
Brunswick County, NC
Hi Bob:
I think I found a bug as well with the new version. The feed description or feed name on the Icecast server gets changed to (RF). I've provided screen shots of one of my feeds showing the difference between v2.0 and v1.13 (using WinAmp). The previous version v1.13 presents the feed description or feed name properly (2nd screen shot in parenthesis). This example is using a PSR-600. I see the same issue with a BC796D as well.
Thanks - Mike
kenmaples
Port Orchard, WA
Any way to disable the audio scope? The new version is running hot. I am running on OLD hardware, but with 1.1.3, RadioFeed runs about 1-3% CPU constantly. on 2.0 it is running 7-15%, and when there is audio it is pushing 65-80%. Again, I am on old hardware, but I thought I would ask.
