How do i set it up to autostart when the system reboots? I have the option to start checked off and i have it in my startup, the program starts but it will not start connected to RR
What did i do wrong?
In the options tab look for "Start Up - Source Client & Web Server Use Last State When Program Closed" and check that.
Yep have that checked, what happens is..... if i disconnect and then shut down the computer. When i restart the program opens but is not connected to rr. I have auto reccoenect in 10 secs also checked off.
However if i X out of the program and reboot it looks like it opens up and starts the broadcast.
Thanks for this program...
This fixed my alpha tag woes with my Pro 106.
For the wishlist: Tag support for the 310/410 models. Thanks!
For the wish-list: a client.
While web-based streaming is great, I use Proscan for my BCT-15, but I also use it to stream audio from my Ten-Tec 320. Having a client with little to no delay, is great when you're tuning a SW receiver remotely.
Proscan does the job, but would be nice to have it on another computer without needing another licence, and without the overhead of a full copy of Proscan, Radiofeed with a client would do this nicely.
Sorry. You lost me. Client as in what? ProScan Remote Over IP? Monitor? Control? Source Client? Media Player built in? Anyways it won't fit into the objective of RadioFeed and i have some cool stuff I will be doing to RadioFeed.
Like remote scanner over IP but without the control. Just audio, and display (for supported scanners) but without the buffer delay you get with the web-based feed.
I know that's not what it's designed to do, and I'm probably the only one who'd use it now that I think of it.Anyway. just wishing...
Isn't the buffer size determined by the host software? Proscan seems to be about 5-15 seconds. Radiofeed is WAY longer, using both Mediaplayer and f-stream
haha... i just looked at my uptime in Radio Feed and it says -11:-22:-15..
and its counting down....
Whys it negative?
