New Orleans TFR
Actual TFR
FDC 5/7601 ZHU PART 1 OF 2 FLIGHT RESTRICTIONS NEW ORLEANS, LA. EFFECTIVE IMMEDIATELY UNTIL FURTHER NOTICE. PURSUANT TO 14 CFR SECTION 91.137(A)(1) TEMPORARY FLIGHT RESTRICTIONS ARE IN EFFECT WITHIN AN AREA BOUNDED BY: 300622N/0902611W OR THE RESERVE /RQR/ VOR/DME 80.0 DEGREE RADIAL AT 8.0 NAUTICAL MILES THEN TO 301017N/0895411W OR THE RESERVE /RQR/ VOR/DME 80.0 DEGREE RADIAL AT 36.0 NAUTICAL MILES THEN TO 295406N/0895324W OR THE RESERVE /RQR/ VOR/DME 105.0 DEGREE RADIAL AT 38.0 NAUTICAL MILES THEN TO 295157N/0901503W OR THE RESERVE /RQR/ VOR/DME 125.0 DEGREE RADIAL AT 22.0 NAUTICAL MILES THEN TO 295100N/0902232W OR THE RESERVE /RQR/ VOR/DME 140.0 DEGREE RADIAL AT 18.0 NAUTICAL MILES BACK TO ORIGINAL POINT AT AND BELOW 5000 FEET MSL TO PROTECT PERSONS AND PROPERTY ON THE SURFACE OR IN THE AIR FROM HAZARDS ASSOCIATED WITH THE EFFECTS OF THE HURRICANE, CRITICAL INFRASTRUCTURE LOSSES, AND EMERGENCY OPERATIONS; TO PROVIDE A SAFE ENVIRONMENT FOR RELIEF AND LAW ENFORCEMENT AIRCRAFT OPERATIONS; AND TO ADDRESS THE LOSS OF RADAR, AIR-GROUND COMMUNICATIONS, AND AIR TRAFFIC CONTROL (ATC) SERVICES. END PART 1 OF 2
FDC 5/7601 ZHU PART 2 OF 2 FLIGHT RESTRICTIONS NEW ORLEANS, LA. ONLY HURRICANE KATRINA DISASTER RELIEF AIRCRAFT SUCH AS MEDICAL EVACUATION, LAW ENFORCEMENT, FIRST RESPONDER, AND OTHER EMERGENCY OPERATIONS RELATED FLIGHTS IN DIRECT SUPPORT OF FEDERAL STATE, AND LOCAL AGENCIES ARE AUTHORIZED TO OPERATE WITHIN THIS TFR. ALL AIRCRAFT REQUESTING TO OPERATE WITHIN THE AREA MUST CONTACT THE FAA RECOVERY DESK AT 800-333-4286/703-904-4547 PRIOR TO DEPARTURE. ALL AIRCRAFT, ONCE AIRBORNE, MUST CONTACT CBP P-3, AIRCRAFT CALLSIGN OMAHA 44, WHICH IS SUPPORTING RELIEF AIR OPERATIONS DURING 0700-1600 LOCAL IN THE TFR AREA ON VHF 134.9 OR UHF 282.425 (BACKUP FREQUENCY 123.45) PRIOR TO ENTERING THE TFR AIRSPACE. ALL AIRCRAFT WILL REMAIN IN CONTACT WITH OMAHA44 FOR FLIGHT ADVISORIES. THE CBP P-3 AIRCRAFT WILL ONLY PROVIDE ADVISORY SERVICE TO FACILITATE SITUATIONAL AWARENESS AMONG THE PARTICIPATING AIRCRAFT AND WILL NOT PROVIDE ANY AIR TRAFFIC SERVICES. ALL AIRCRAFT OPERATING IN THE TFR AIRSPACE MUST EXERCISE EXTREME CAUTION, AS ATC RADAR, AIR- GROUND COMMUNICATIONS, AND RELATED SERVICES ARE VERY LIMITED OR UNAVAILABLE IN THE AREA. END PART 2 OF 2
