kayleesdad
- Joined
- Oct 22, 2007
- Messages
- 663
i think i just have generic xt settings and may not be instructive as it appears that both scanners receive okay without an antenna from my residence - maybe because 100X has to communicate from downtown Tampa and the antenna on the east side of the RC ariplane field may have some additional power to it:
p25 LP filter is "Off"
p25 adjust mode is "3"
p25 adjust level is "50"
Digital AGC response time-->Response time is "0"
Digital AGC reference gain-->Reference gain is "0"
i don't know if the p106 has a comparable control that makes the scanner hold on a system solely for a fixed period of time other than the tsys specific "dwell" setting which only goes up to 0.2 seconds or radio system defined (and a variety of other control channel specific settings like roam, quality of reception, etc...), but maybe i probably don't understand exactly what xt's "set hold time" really does or what all those p106 setting do. i thought the xt system "set hold time" is used to cause the scanner to spend more time on a particular system (tsys in pro106) and that seems to be what it does, and what else it does i don't know.
"dwell" (non-global tsys specific setting) for the p106 is only up to 0.2 seconds or radio system defined, and is described in the instructions as:
Sets the amount of time the
scanner dwells on a Motorola,
P25 or EDACS system control
channel for activity on programmed
talkgroups. Use 0 for
automatic mode, which uses
control channel information
to determine when all current
talkgroup information has been
broadcast by the system.
I dunno, the p106 doesn't seem to have an equivalent system (tsys) "set hold time" in the global p25 settings (below and attached). guess i'm just missing it.
96CC HD2 TO 9600CC SQ to HD2 timeout 30 10–250, x10 ms CC detect timeout CC HD2 Timeout P25 Trunking Length of time to wait for P25 control channel detection timeout
96VC SQ TO 9600VC RF SQ timeout 50 10–250, x10 ms VC RF SQ timeout VC SQ Timeout P25 Trunking Length of time to wait for P25 voice channel RF squelch timeout
96VC XF TO 9600VC SQ to XF timeout 100 10–250, x10 ms VC Digital timeout VC XF Timeout P25 Trunking Length of time to wait for P25 voice channel digital IMBE timeout
HD2 Qual DG HD2 qual time to unmute 96CC 100 10–250, x10 ms Qualify CC in analyze Qualify Time (Digital) P25 Trunking Length of time to check for a P25 control channel before unmuting in Analyze
