new pro 96 issue....
jeffy
....bought my new Pro 96 a few hours ago. All I need for now are the Morgan county Ohio digital frequencies. I put the 5 digital freqs. I found here on R.R. for Morgan county. For whatever reason I can't get the dadburn thing to scan... when I hit scan here's what's displayed...
O.2.......
scan down...
any help out there? I can go from channel to channel manually.
Tom_G
Rocky Hill, CT
Looks like the radio is scanning both bank 0 and bank 2 in open mode.
What bank did you put the frequencies in ?
You can toggle a bank on/off by selecting the number of the bank.
ind224
Indianapolis
I prefer scan up and it seems to make a difference here in my area. You might try control channels only and open the squelch. Manually scroll through them to make sure you are getting a good signal.
N8DRC
Grass Lake
Hello
If you have win96 software I have a file for your county when I visit the area...
jeffy
pro 96
I toggled bank 2 off. I put my freqs in bank 0. Still not scanning. to be honest ... I might quit for the night and go back at it tomorrow. Radio shack was zero help. Thanks yous guys for the replies. I'll let yous know when I get it squared away.
jeff
jeffy
pro 96...
I got up this morning, initialized my pro 96, programed the five 7 digit Morgan county Ohio frequencies the way the owners manual says and still can't get it to pick up the frequencies while in the scan mode. I can pick them up manually but that's it. I called the RADIO SHACK help line, explained my problem and she (help line person from Dayton) didn't know what to do to fix it. Oh well....
jeff
hoser147
Grand Lake St. Marys Ohio
jeffy
scanner....
Go to here and this should help ya http://wiki.radioreference.com/index.php/Category:Programming_Shortcuts I would strongly suggest to get the most out of your scanner Check out Win 96 http://www.starrsoft.com/ and get a subscription to RR (here) and you will have that scanner going well in no time. Win 96 gives you a 30 day Evaluation period before you have to buy it but its well worth it. Good Luck and Good Scannin Hoser
http://wiki.radioreference.com/index.php/Programming_Shortcut_Pro-96
Thanks Hoser... just in the last 5 minutes I've got it working. Amazingly I did nothing different... just an anomly I guess. Thanks for the links sir.
jeff .... Ohio
