New Pro-96 User needs help w/trunking
Fluke
Ok, I am sorry. I have read the RR Wiki, some other members questions on trunking and the owners manual numerous times and I still havn't got a clue how to program my scanner for trunking. I would like to program Langley AFB's frequencies they are on this page: http://www.radioreference.com/modules.php?name=TRSDB&sid=794
Can someone please tell me what I need to do?
Thank you for your time and patience. :)
stevecubfan
thornton colorado
langley air force base
program the control channels in chosen bank starting at channel 0 if you here the control channel press program then trunk it should start at channel 00 punch in the talk groups then press scan when programming control channel and talk groups make sure you are in mot mode if not press mode button on bootom left of scanner until mot appears if you see talkgroups appear and here no sound it is probably encrypted and you can not monitor it
stevecubfan
thornton colorado
one more thing you only have to program the control channels hilighted in red and blue
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Welcome Fluke to the site.
Along with stevecubfan's suggestion you must enter this information
in order for the system to trunk track.
Custom Frequency Table
Base: 406.0000
Spacing: 12.5
Offset: 380
Review the section for UHF trunking in your manual.
When prompted by your scanner make sure the Base, Spacing and Offset
match the table from the database. They may have different numbers that were preset at the factory.
Once you do these adjustments and program the control channel freq's
you should be good to go.
Good luck.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
In your Langley bank Press
PGM
TRUNK
FUNC + 2
406.0 then ENTER
380 then ENTER
Use the up or down button until line 4 is 12.5 then ENTER
Press FUNC + 3
Use up button until line 4 is Table then ENTER
Press SCAN.
BTW, get Win96 and a cable, I've got a p96 file with Langley, York CO, Newport News, Hampton, Virginia Beach, Norfolk, Norfolk Nav Base, Chesapeake, Portsmouth and Suffolk.
