safetyobc
What if Uniden developed a product that would equal the V-Folders of GRE.
Create an attachment (small enough to carry with you) that you could attach to the scanner through the computer cable. You could previously load system setups into the new attachment from your computer via Butel or USAD or some other software, and carry it with you. (lets call this new scanner product UPM-Uniden Portable Memory or PDM Portable Dynamic Memory, for instance PDM-246T)
Then when you needed the other setups while traveling or whatever, you could connect it to the scanner and use the Master - Slave function to load the system setups of your choice. Similar to a memory stick in digital cameras as far as removable memory goes. Maybe we would be able to save multiple setups on the "PDM" then upload them as needed. Kinda makes you able to travel without the laptop.
This could be similar to the VFolders the GRE uses just as an external device for the Uniden models....... I guess I am thinking more along the lines of the BC246T, but it I guess it could be set up in banks and channels for older models. How about it UPMan?
Oh yeah, if Uniden (or GRE) uses this idea, I want my royalty check! :wink:
Seriously though, I think this would be a great product!!!!! Just my idea though. What do you guys think?
