New purchase MD782G.....questions....
ctrmass
oean county, nj
So I bought a new (used) Hytera last month.
It's running firmware: A3.05.10.001 (yea, I know it's old....)
CPS version: v8.05.06.08.002na
I finally got around to programming it, and I'm seeing the big light blinking green, but not hearing anyone. Well, sometimes I do, but most of the time, not.
Netwatch confirms some's talking on said talkgroup. I have RX groups programmed in the CPS
I put up a question on facebook. The answer was I need to click the box marked "Rx group including Tx contact" but it does not exist in my CPS.
so
This is my question(s)
1 If I get the new CPS, will it work with the radio as is?
Because
2 I tried to upgrade the FW but it said "The firmware version is beyond the upgradeable firmware v A3.05.10.001:" or something close to that.
3 Will I lose wideband? I have it now....
Oh, and where is the older firmware downloadable from? I cant find it anywhere!
Soooo, what do I do?
I will take guidance/suggestions.....
MSS-Dave
Generally Central Florida
so
Because
I'll try to help. Yes, your F/W is old but should work on conventional DMR fine. I am using 8.05.06.008 and can program radios with V 5.xx OK. Since you see the busy light blink on activity but still dont decode audio, I'm going with a programming issue with your talkgroup.
What version off Firmware did you try to upgrade to? If you tried to go directly to 8.xx, that won't work. It will have to be stepped at least 2 times as you have to have 7.00 first to go above that.
Not sure if you will lose wideband if firmware is updated from that old version. I did on some of my stuff so I'm asking Hytera about that. Firmware isn't available publicly AFAIK.
"RX group including TX contact" in in newer firmware, probably at least 6.x. even if using 8.05 CPS.
Check this.... make sure your TX contact info is correct. Make sure your RX group has the TX contact in it. THEN, make sure in your Digital Channel you have the right RX group list selected. Assign that to the zone and see if that works.
ctrmass
oean county, nj
Well, I dedicated 4-5 hours to this today.
I'm now on FW version....A8.05.07.004
And I can now run CPS Version V8.05.05.008NA2 . I'm in my happy place.:D
Thanks for taking the time to reply Dave.
Hytera should keep these older FW updates somewhere accessible.
Here is a dropbox with some old files.
I asked the owner, he had no problem with me sharing.
https://www.dropbox.com/home/Hytera MD782 Programming Software and Cable Driver
MSS-Dave
