New Putnam County DMR Conventional System
calebotten15
Wyoming Il
Seen Today There Is A new FCC License Putnam County it look's like it will be the Same type of system as Marshall Counties and this one shows it will have 4 towers
west-pac
I already programmed it into my scanner tonight and just going to wait and see when it comes online.
I've programed new digital system freqs in my scanners as analog freqs many times. When your scanner starts making a bunch of digital noise on those freqs you know that new digital system in on the air; then you can bring up your software to get the information you need to program a digital scanner. 👍👍
calebotten15
Wyoming Il
Putnam County DMR Conventional Network
WRUH639
Site 1 453.1625 HENNEPIN cc unknown
Site 2 453.3375 SPRING VALLEY cc unknown
Site 3 453.525 Granville cc 12
Site 4 453.7625 MAGNOLIA cc unknown
Talkgroup 2000 Law Dispatch Putnam County Sheriff Granville Police Mcnabb Police also Countywide Fire & EMS Paging
cubn
Marion/Johnson County, IN
WRUH639
I've added it to the database: Putnam County Trunking System, Multiple, Illinois
lu81fitter
Marshall County, Illinois
Had PROSCAN running today. This is what I've found.
Spring Valley ---> CC 11 Hennipen ---> CC 10 Granville ---> CC 12.
Nothing for the Magnolia tower.
Also, I know the FCC ID probably lists tower sites by local cities, but the locals know the Granville tower as "Clearview" and the Spring Valley tower as "Fox Run". Just a little tidbit of information.
calebotten15
Wyoming Il
Ok any other Talkgroups found
lu81fitter
Does anyone know if the talkgroup is simulcasted across all towers on this new system?
The only towers that are up on the Putnam County DMR system right now are Hennepin and Clearview/Granville, and it is only the sheriff's department. EMS and fire are still using analog sites on VHF at Hennepin and Magnolia.
EDIT: And yes, it is simulcasting on both towers at this time.
Mex
Surrounded by cornfields
Are thoose 2 sites linked or should I put both in? Also is the slot changing constantly? I'm trying to program this into a XPR.
lu81fitter
I am listening on a Uniden BCD996P2 with a DMR upgrade. I do not know if the slot is changing. Right now, I have the Clearview tower programmed in to an analog group to speed up scanning. It still comes through because I have the DMR upgrade. I'll switch it over to the DMR system I have programmed and hook it up to Proscan again to see what comes up.
