Take a look at the last two 651 and the pro 652
Scanners, Patrol Scanners & Handheld Scanners | RadioShack
Rush right out and buy both. Better yet get two each!!Ok I looked, now what?
These are not news, a number of discussions going on about them in this very forum. They look similar because they are the same thing, just built by Whistler instead of GRE.Looks awful similar to the pro-106. What is different in this new model?
-SF
Sent from my iPad using Tapatalk
Simmer down, I was just pointing out something that I came across. I wont buy either one myself, I have a plie of rat shack scanners, its a long list the newer ones are 95,96,97,2051,163,164 then the gre's 500,600,800 then the unidens HP1,436,536 I was just pointing something out that I had not seen yet and they are not in the wiki yet.Ok I looked, now what?
The Whistler models are, but not yet as the RS modelsI was just pointing something out that I had not seen yet and they are not in the wiki yet.
I'm fairly certain many of the new RadioShack and Whistler scanners and their wiki pages will eventually be turned into redirects (or the appropriate GRE/RadioShack pages will be moved/renamed) once someone actually picks one up and verifies that the changes are cosmetic in nature.The Whistler models are, but not yet as the RS modelsI was just pointing something out that I had not seen yet and they are not in the wiki yet.
Whistler Scanners - The RadioReference Wiki
The user manual released for the Pro-651 (on the RadioShack website) says that cloning is cross compatible with all the GRE scanners including the PSR-500, PSR-600, Pro-106, Pro-197, and Pro-652.I am tempted to pick up the new 106 clone just to play with and see if there are any improvements that I perceive.
Does anyone know if I can clone my 106 to the 651?
Great, thank you!The user manual released for the Pro-651 (on the RadioShack website) says that cloning is cross compatible with all the GRE scanners including the PSR-500, PSR-600, Pro-106, Pro-197, and Pro-652.
Highly unlikely is my guess from what i have read they are supposedly identical.Hi,
Does anyone know if the Pro-651 has encrypt mute feature on p25 encrypted transmissions?
It was the biggest failure of the pro-106
