Paco-Jerte
You Member, Member!
Got this info from a social media site. Tried on both 950Pro and 889Plus and worked. YMMV
To activate Super Mode on the Radtel RT-950 Pro, you must perform a specific startup procedure.
• Turn off the radio.
• Press and hold the PTT button (the large transmit button on the side).
• Simultaneously press and hold the "8" key on the numeric keypad.
• Turn on the radio while keeping both buttons pressed, then release them.
What Super Mode Does
• It unlocks extended transmit (TX) and receive (RX) frequencies across the entire band.
• It enables additional transmission settings on the various VFOs.
• Caution: Using frequencies that are unauthorized or unsuitable for the final amplifier (PA) design may damage the device or cause interference.
