busterphenajo
Hi, earlier I only "heard" of the enc, not able to hear anything. Today I'm, picking up TGID 309. Unknown to me.
Using Op-25, linux
Using Op-25, linux
TG 309 converted to the old system would be TG 4944, Solid Waste Management.Hi, earlier I only "heard" of the enc, not able to hear anything. Today I'm, picking up TGID 309. Unknown to me
403 would be 6448, Busesand TGID 403 is?
I am curious as to what has happened to the Roseville PD with communications today. They seem to have dropped off the P25 system. I am watching the control channel traffic. I would see it if they were using encrypted channels or other channels, but I'm just not seeing any activity. As of 16:35, the last police activity was at 13:27. Obviously, SOMETHING has to be happening, but I'm not seeing it. I am seeing all the other traffic, including all the other city services, just not police.
I am curious if they started a SECOND independent system with Phase II... I am seeing a 6.25 KHz constant signal on 852.375 MHz. My software, unfortunately, cannot handle Phase II control channels or traffic.
I have been monitoring this system with UniTrunker for weeks. The control channel does change often. If you stop getting traffic, check to make sure you have the presently active control channel programmed and unlocked.
Have YOU seen or heard any police activity on the P25 system today?
crucialcolin said:Ahha Found it! Looks like Roseville PD is currently broadcasting on 851.5125 mhz called 8TAC91 under the 800 mhz National Mutual Aid/Interoperability System.
I am using a tapped scanner. I only scan one bank/list with all non-related frequencies locked out, so it follows the control channel changing.I used to use UniTrunker before moving over to SDRTrunk. The one feature I miss from UniTrunker is that I could set one dongle for every frequency the system uses for a control channel so it will automatically switch to the active one when it changes,
The reason you haven't heard any normal police communications on the P25 system lately is that they've had several catastrophic failures of the system as well as coverage problems.
CBS13 did a story on the issues:
https://sacramento.cbslocal.com/201...g-new-roseville-police-communications-system/
It sounds like they're using a backup in the meantime.
Saturday night they had a complete failure of the system.
I got a bit of a chuckle seeing the news story because they credited recorded audio of radio traffic from Broadcastify. The reason that amuses me is that I'm the one that feeds Broadcastify. It is probably best not to get the credit personally anyway. I see that they are back and active on the P25 system now that I've gotten home from work.
