marksmith
The antenna it comes with is actually pretty good.
536/436/ws1095/996p2/996xt/325p2/396xt/psr800/396t/HP-1/HP-2 & others
***actually i disabled everything but law (since that is all i'm really concerned with)***
Just a quick check so we can understand how the scanner is set up.
Select menu and "Set Scan Selection"
Under "select Lists to Monitor", the only thing that should be "ON" is "Full Database". If anything else is loaded - shut it off.
Go back one menu and goto "Select Nationwide Systems". There should be a lot of "ON", a few with dashes, and no "OFF"
Zip code should be yours.
(Don't mess with the range for now)
Squelch should be 3
Volume at 8
Keep the scanner antenna vertical.
If you want to check the database you can go to "manage full database" and go to information (it should be fairly current), and review the avoids (there should be none).
Maybe another member is in your area and y'all can meet up.
Try scanning from this Favorite List and see what happens.
I'm with Jon and Mark - I don't see a problem.... Do you believe there still is some type of problem? If so, what?
