New scanner
407AR
Pee Dee, SC
Just bought a BCD325P2 and I have no idea how to program it. Need Palmetto 800 and EMS. Anyone out there that can talk me thru it or willing to do it in the Pee Dee?
darlington sc
i can do it for you it just depends on what all you want in it fro where youre at you should be able to get horry co and marion as well as the pal 800 sites in dillon and conway as well aqs georgetown also be aware that horry co will be changing over to the pal p 25 soon
HummerMike
Abbeville, S.C.
Hello ....... programming is easy. The easiest thing to do is to download the BuTel software for your scanner. Upgrade your membership here. Connect your scanner to a computer with the supplied USB cable. Run the Butel program. It will show where you can connect to Radio Reference data base. Then select your state , county. Select the conventional frequencies you want and download. Then do the same for the digital frequencies you want. You should be set to go.
Mike
