New scanners?
funtimeguy
Western Iowa
This may have been discussed here before, if so sorry to bring it up again, but does RS have any new digital trunking scanners on the horizon?
whooey
Gainesville, FL
You will not be disapointed my friend, except for the paint on the case, not the buttons wearing off...
funtimeguy
Western Iowa
The only thing I'm worried about is how hard it is to program. I have a BC245XLT that I had a little trouble programming it to do trunk tracking, but also have three Pro-95's that I use win95 to program with and with the software they're a snap, but from what I've seen on here even with the software the BCD396T is kind of tricky to program.
PNW
The BCD396T menus and setup are both pretty close to the BC246T from what I understand.
While I don't have a 396, I do have a 246. After a couple of hours of reading the manual, browsing the Radio Reference forums, and playing with the radio & software, I got it figured out.
The menus do away with the age-old problem of many different keystrokes to accomplish a simple task. With the 246 you simply go into the menu, scroll to what you want to change, and change it. That simple.
I'll never go back now that I have a taste of the easy menus and great idea of dynamic memory.
PNW
whooey
Gainesville, FL
Please don't let that be the reason for settling for any other radio. The 396 has features that are incredible!!! Stuff thats never been seen in another scanner!!!
10 custom searches, fuhgedaboutit!!!
In these searches you can search for control channels. You know what that means???? Say the trunking control channel is 868.2500. You set the custom search from 868.0 to 868.5, then set Control channel only search (super easy to do). Then when it starts searching, it hits the control channel next thing ya know youre scanning!!
This is also a good method to find trunked systems you never knew about!!!
There is too many features in the 396, unless you cant afford it, there is no reason not to get this radio.
If it is difficult for you to program, thats why this forum is here!! 8)
Good luck and let me know,
Brandon G.
whooey
Gainesville, FL
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
funtimeguy said:
I'm leaning heavily towards the 396T, but also considering the BC296D.
I and others will agree, you should go w/ 396T!! Its smaller, thinner, cooler, newer, and full of features, and the blue backlight is sweet. 8) I never owned a 296, this is all hearsay.
Its well worth the $20-50 bucks extra, trust me.
Someone back me up here!!
Nuff said.
