SDS100/SDS200: New SDS Firmware is here!
viggendriver
FWIW, I found the update by chance and have been using it about a day. I logged in here to see what changes might have been made and I definitely noticed improved audio on P25 before I read anything in here. I haven't noticed anything else but I'll take the audio improvements.
NoahWL
I haven't noticed any differences since updating. P25 P1/2 audio quality sounds identical to me (listening primarily to the Starcom system). Still patiently waiting for future improvements... I would also like to know what "housekeeping" refers to, so we can have a better idea of what improvements or regressions to look out for.
XPS720
Windham County, Connecticut
When I did my weekly Update on Master Data Base I also noticed an update was available for Firmware on my BCD536HP and SDS200. The update was very easy and it tells you to remove USB cord for proper update. I now see version "1.28.16 " on my BCD536HP and version 1.21.00 on my SDS200 Why do I see different version's? Are these the latest and the correct version and what was updated?
dave3825
Suffolk County NY
XPS720
I am not sure about this update as my SDS200 system says I have main version 1.21.00 and sub version 1.02.01. When I check for firmware update it says I am up to date on my SDS200.
dave3825
Suffolk County NY
The op has a SDS200E, a model sold overseas. The latest firmware for that is 1.22. In the US, and with the SDS200, the latest is 1.21.
donc13
Grand Junction, CO
I presume you checked via Sentinel. Did you update your version of Sentinel? It should be 2.03. You can get 2.03 from the link here :
Another possibility is your internet connection was flakey and/or you use T-mobile for internet service.
dave3825
Suffolk County NY
Scroll up to post 207. Someone with an SDS200E (over seas model) posted about that models firmware. The E model runs firmware 1.22
Unless something changed, 1.21 is the most up to date release for the American model (SDS200) and 1.22 is the most up to date for the overseas model (SDS200E).
XPS720
Yes the 1.21 is the latest one for BCD536HP and SDS200
NikonFE2
Ohio
I'm in the U.S. and just discovered the firmware update today. My SDS100 now reads Firmware 1.21.00 and sub 1.02.01.
spikestabber
Toronto
I've been running that firmware on 100 & 200 for about a month now, anyone that can't hear an improvement on P25 decoding either has revised hardware the firmware doesn't improve upon or should get their aging ears checked. There is much less 'gurgling through water' sound on the voice. Maybe this all depends on site & bitrates, I don't know, but its there. I didn't update both of my units at the same time, waited in between, thought I was just hearing things at first until I did the 100 in the car.
