SDS100/SDS200: New SDS Firmware is here!
bravo14
Polk County FL
I just remembered uniden did have a google drive firmware update download. I thought I saved the link somewhere. Is that google drive still around or not listed any longer?
USASA
Falcon, Colorado
Hi All!
I have tried all of the suggestions, nothing works! I have my BCD536HP and my SDS100 on Sentinel v2.03. It is set for the SDS100. Every attempt I get "YOU ARE UP TO DATE." It will not update the SDS100 card in the radio. I can edit colors, I can do all the SDS100 related things. But not UPDATE!
Joe Bearcat, Find The Fix! Please.
Put the file out so we can try just writing it to the card. That is if that will work.
Hay! If you have updated your SDS100, please put the file in a drop box for others to use. That may be the answer for us poor slobs. It is worth a shot.
Al
U.S.A.S.A
JoeAracci
Liberty , NY
How do i update to Sentinel from 2.02 to 2.03, I cant find it anywhere
Can you tell me more all the updates for the sds 100 n 200
teknishun
Alvin, Texas
I just updated my SDS-100 using the new Sentinel v 2.03 rev 00 and now I have
firmware version 1.21.00 with sub version 1.02.01 Looks as if the SDS-100 updates are working now!
teknishun
Alvin, Texas
Hey Joe - The Sentinel v 2.03 is a ZIP file. Download the zip file to your pc and then expand it.
The run the install.exe file This will over write the old Sentinel and replace it with the
newest version 2.03 rev 00
As to what got changed ..........(I hope this copy and paste works)......
SDS200 Firmware Update Change Log
All firmware updates are done using Sentinel.
Before applying updates, you should back up your programming. Always use the latest version of Sentinel to update.
1.21.00 Main (6/29/2022)
This firmware applies the following enhancements and bug fixes:
  • Added 2.5 kHz and 3.125 kHz steps to the Custom Search and Discovery mode.
  • Housekeeping update to accommodate revised hardware.
  • (latest version of Sentinel (2.03) required to use these features)
pinballwiz86
Missouri
I bought both the SDS100 and SDS200 at the same time from PSO (May 2022). The SDS100 needed the update, but the SDS200 already came with firmware version 1.21.00 installed. I haven't noticed any difference with the SDS100 thus far.
garys
Texas
Thanks. Apparently someone at Uniden reads the forum! :D Just updated and will run the SDS100 for a while to see if there are any improvements to the audio. I did some listening to my SDS200 while I was out driving around, but I'm not sure the audio is any better. Although there MIGHT be some improvement on analog.
Just updated the SDS100
