I just received my SDS200. I programmed it using the latest version of Sentinal. When it receives an analog signal on the UHF-T band and VHF-HI band, the audio sounds distorted , as if I was next to a high voltage source, which i am not, and the distorted audio is way too loud. I set the UHF-T frequencies to NFM (was standard FM) and the audio cleared somewhat and the volume level was lower. The VHF-HI (Fire departments) were already set as NFM
Has anyone experienced this before?
I wanted to check before I return it to ScannerMaster.
Thank you
Thank you
