Probably a typo. Most Motorola VHF radios come from the factory 136-174.
If the Radius has the 16 pin expanded accessory connector on the back of the radio, connection to a APRS tracker should be easy. Push To Talk, Transmit Audio, Receive Audio, Carrier Detect, Power and Ground are all available on the B308 connector. Using RSS, the accessory connector may need to be programmed for Carrier Detect output. A B308 interface cable will be needed. They are easy to acquire.
Nope... Thats right... 146-174 on those radios. There is NO Spectra or Maxtrac/Radius radio made that covers 136-174... There is splits within that range, depending on the radio, usually though a Spectra or Radius is 146-174 for the high split, and 136-162 for the low split, but the low split radios are nearly impossible to find.
I should know, been trying to find one for years to do a comparison and write up another article for the Repeater Builder website.
However the Radius/Maxtrac mobiles will do 144.390, but you need to blank and reinitialize the logic board for the lower split, in a way tricking it into thinking it is a lower split radio. You can program it at 144.390 on a higher split radio using the "shift" trick in the software, but the transmit power will go whack on you and your going to have to add a manual trimpot inside the radio to manually control the power level. I have seen Maxtrac's that try to do 80w at 144.390 because they don't know how to handle the frequency. So what i normally do is reprogram them as a low split radio to get the power adjustment to work, however this still doesn't bring the receive sensitivity back to spec and your going to have to just live with it or try to retune the radio, which is a lot of work and adding slugs to the front end coils, etc..
Been there done that...
For a simple tracker the Maxtrac/Radius radios are ok since most of the work is just transmitting a packet, but you can cause packet collisions since your not hearing everything.
The Spectra is the same challenge....
(UI-View has been running here crash free for years!!)
