New to GMRS in Brooklyn/NYC
seanpopke
I just got my GMRS license and looking for where to get started. Are there any recommended repeaters in the area with good coverage in the Brooklyn, Manhattan, and Jersey City areas?
Thanks in advance!
03msc
RF is RF
The Natural State
Thanks in advance!
Here's one listed on myGMRS.com:
https://www.mygmrs.com/view?id=280
Check the use details/restrictions before using. That particular one says they require permission if you're going to use it regularly.
There may be others; that was just a quick search on that one site and you may find other searches will yield more results.
Best of luck!
FrankNY
New York, NY
I hate to say it, but that particular repeater has been out of commission since July 11 of last year. It transmits 0-1-5 DTMF tones every 15 seconds and does not function correctly as a repeater. There's a long thread about it over on the MyGMRS.com forums. The machine needs attention but no one has fixed the problem yet even after all of these months.
I'd post a link to the thread, but it's in the Private Discussion section of the board and you would need an account and need to be logged in order to read the thread.
https://forums.mygmrs.com/
There are indeed others, several actually, but almost all require permission from the owner to use. The MyGMRS.com Web site and associated forum (bulletin board) are excellent sources of information.
Regards - and good luck!
Frank.
seanpopke
Thanks for the info so far. I've signed up for the mygmrs.com site and requested access to a few repeaters. How long does it usually take to hear back from someone?
FrankNY
New York, NY
In my experience, usually just a day or two, longer of course if the person is away on vacation or traveling for business, etc., and isn't checking their personal e-mail. If you wait a week or longer and don't hear back one way or the other, then you should try to locate an e-mail address for the individual and write directly to them. Hopefully, that will yield better results.
Now that you're registered for the MyGMRS site, you should also have login access to the Forums. The thread about the (presently non-functional) repeater mentioned earlier in this thread is in the 'Private Discussion' section of the board. The thread title/topic is 'Interference on 675'.
Frank.
