New (to me) APX Radio - cannot transmit on -p25 conventional
gip127
Member?
New Jersey
I bought an APX7000. It transmits fine on analog UHF/VHF. I tried transmitting on UHF conventional p25 and nothing comes across any other radio. I tried using three. The radio receives p25 conventional no problem.
Thoughts?
Time for a refund?
K2NEC
You checked all of your personalities right? All the correct conventional personalities are in the right zone channel assignments? And the right conventional frequencies are selected in the table?
gip127
Member?
New Jersey
Yes, I checked the codeplug over and had a buddy check it too. Everything is right
MTS2000des
5B2_BEE00 Czar
Sounds like an alignment may be in order. P25 alignment is critical, a 100KHz off freq on analog won't really affect performance, but will render BER so high on P25 you get nothing. When was the last time the radio was aligned?
gip127
Member?
New Jersey
Unsure. The radio keys up, you see the red light/tx symbol but no other radio receives it...
N4DES
Retired 0598 Czar ÆS Ø
South FL
If you open the squelch on one of the other radios do you hear anything?
My thought is the direct frequency is still the default and the box is checked in the personality.
gip127
Member?
New Jersey
Thanks for the answers everyone. I am usually transmitting on a 460 range freq, I changed to 501 to try p25 and it worked. Proving the alignment theory. Alignment to follow
chrismol1
P25 TruCking!
yep.
I have a DiagnostX on my trunking system that flags any RID with high BER or freq drift. as little as 50Hz and BER starts climbing.
I wonder, will there ever be the day we see Autotune - Over The Air, it would keep adjusting and TX feedback until it hits the values it needs while using LTE or something as a secondary feedback line. I have no idea if that'd ever be feasible. That'd be an advancement, sorta like apx next lte programming anywhere, things are different than the old days. Its still cool to me, to program my XPR7550e over wifi without touching a cable to it
