New to RCS South: (TGID 38883?)
slickwillyone
Hello to anyone who can help answer a few questions,
I'm new to the RCS South Loop (CV, ELC, NATCTY, LMGRV, LAMESA, CHP, SDSO, SDPD, etc). I'm working with a BC250D-P25 and trying to dial in most useful TGID lists. I've been using the RR database and running in search mode and reviewing logs (PROSCAN 4.3) to find the most relevant/used TGID in the area. However, the RR database lists numerous TGID that seem inactive (e.g. CHP outside ELC) and does not have others that are very active (I can't find a reference to 38883 which is very active.) Does anyone have any intel on exactly what 38883 is and/or have some useful guidance on dialing in these areas? For example, is there a local Community Of Interest, forums, blogs, etc? Any and all help is greatly appreciated.
v/r, Slick
SDWolfman
San Diego County, CA
Talkgroup 38883 is when talkgroup 38880 (CHP El Cajon Dispatch East, Resident) is being patched with another talkgroup.
D+0 Normal Talkgroup
ID+1 All Talkgroup
ID+2 Emergency
ID+3 Talkgroup patch to another
ID+4 Emergency Patch
ID+5 Emergency multi-group
ID+6 Not assigned
ID+7 Multi-select (initiated by dispatcher)
ID+8 DES Encryption talkgroup
ID+9 DES All Talkgroup
ID+10 DES Emergency
ID+11 DES Talkgroup patch
ID+12 DES Emergency Patch
ID+13 DES Emergency multi-group
ID+14 Not assigned
ID+15 Multi-select DES TG
Motorola Type II - The RadioReference Wiki
slickwillyone
SDWolfman,
Thanks for such a fast response. My owners manual is pretty skimpy on detail when it comes to status bits, but this clears everything up. Sorry this turned out to be a newbie question, and the help is much appreciated.
v/r, Slick
MtnBiker2005
San Diego County, California
Take a calculator.
You can validate talkgroups by dividing them by 16. If it divides evenly, that is a valid talkgroup ID. If it is not even, you have found a patch group. Every base talkgroup WILL divide even by 16. Motorola radios are programmed with HEX numbers and are HEX based. Hex is a 16 base counting system.
slickwillyone
MtnBiker2005,
This is great info and makes perfect sense for a HEX based system being offset by multiples of 16. I found that I can toggle the status bit on/off each trunk bank so this becomes transparent.
v/r, Slick
