- Joined
- Aug 20, 2022
- Messages
- 133
After some discussion in the Uniden Tech Support area about ProScan, I took the plunge and purchased a key. I knew it has some features that Iike such as logging, remote control, recording and audio. All of that to get working only took minutes. Now what I have learned and I am running v19.7.1 and for now only connecting to the SDS200.
(1) ProScan helped me find an issue I did not even know was there. First thing I did was a scanner read. I noticed a favorites list that I had previously renamed in Sentinel. When pushed from Sentinel I was sure to delete all favorites with the checkbox and push new copies. I am not sure how that happened but it was evident in ProScan there was an issue. To be sure I deleted all the favorites from ProScan and did another pull - there again. To fix the issue I used Sentinel to wipe all device settings and push my custom settings, the full database and favorites (with the delete). This rogue favorites list was not there on next retrieval from ProScan. Strangest thing was the rogue list did not show up in the favorites list on the scanner. ??
(2) ProScan does NOT play very nice with ESET nod32. On launch as it does its update check it gets blocked. The same when I go to proscan.org. This means proscan.org and the IP are blacklisted in the wild. As a temp fix I whitelisted them locally.
(3) Looking at favorites, just a tad different than Sentinel - one must "File menu >> Import Sentinel database" to add a fav list. Ok not a biggie but I do not see the "download" option. I see the "monitor" option and "location control" but not download. Does this mean they are downloaded by default with or without monitoring enabled? Remember in Sentinel one has the ability to create but not download a favorites list. This comes in handy when running more than one scanner since fav lists are common to all scanners.
(4) All features seem to be working. I lost significant cool points having to read the manual and search around a bit to get logging turned off. For me this is something like recording that I will use on an "as needed" basis, not 24x7. A simple feature would be to add radio buttons to the logging screens or check boxes to enable / disable logging vs digging through the "Options menu >> logging tab".
My $0.02! Very nice program!!
