New to scanning
ryanmalott
I live in Clermont county ohio. What scanner can I use to pick them up? They are on the apco 25 thing or what ever it is. Also I want to be able to hear clermont county and also hamilton, but not at the same time, is there anyway to program the scanner to make it where you just push a button to switch from clermont to hamilton. Would I be able to with the scanner to program all the firegrounds in? Are there websites that show all of the frequencies in clermont county
loumaag
Silent Key - Aug 2014
Katy, TX
Have you looked here in the database.
Also notice I have moved this topic to the Ohio forum, where you are more likely to get local replies.
ryanmalott
Thanks I looked around on the Database and found Clermont county, But it dont say what type of scanner I can use to pick up them, With a regular scanner all you hear is the dispatcher only, I want to be able to hear everythnig, I know there is one, but dont know which one I can use. Thanks for the help.
FPO703
Planet Earth
You will need wither a BC296D/796D, BC250D/785D (with APCO-25 Card), PRO96/2096 to monitor Clermont County.
Those are the only radios (short of an actual Motorola radio and that's big $$$) to monitor Clermont County
JediMaster
Cincinnati, OH
And as for monitoring both Hamilton and Clermont it can be done by just turning banks on and off. There's enough banks, channels, and IDs to be able to program both. You will just have to decide how you want to program Hamilton county in. The best way is to use more than one bank. I have mine set up in 4 banks basically for the main stuff (Cincy PD, LE West, LE Central, LE East.)
