new to scanning
jramsey57
Hello everyone
I have a whistler 1065 scanner How can I move things between scan list Everything I have now is on scan list 1 I would like to move some to scan list 2 Thank in advance for any help Johnny
Spitfire8520
Might be slightly less clueless! =)
Colorado
Scan lists are assigned based on the object in the scanner. This means you have to edit the conventional/talkgroup object to assign the scan list it will be in, and you can do multiple scan lists if you want. In software, you select the object and there would then be some kind of option to assign it to a scan list. By hand, you need to edit each object's scan lists using the left & right arrows and the SEL/ENT key.
